Disables the sending of LLDP MED-specific SNMP traps on the specified port or ports.
| all | Specifies all ports on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
Disabled.
If you do not specify any ports, the system stops sending LLDP MED traps from all ports on the switch.
The following example disables sending LLDP MED SNMP traps on all switch ports:
disable snmp traps lldp-med ports all
This command was first available in ExtremeXOS 11.5.
